Ansys Learning Forum Forums Discuss Simulation LS Dyna Collision in numerical wave tank between two bodies Reply To: Collision in numerical wave tank between two bodies
Raman Babu
You can try with *ICFD_CONTROL_GAP card in ICFD simulation which will allow a flow blockage between two
surfaces in close proximity based on a user defined contact distance.
For structural simulation, you can use higher contact thickness to avoid direct contact between two structural bodies.
