Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Self-made car jack – static structural analysis › Reply To: Self-made car jack – static structural analysis
November 25, 2024 at 1:19 pm
kubatycjan
Hi John, thank you very much for your response. Meanwhile before I read your message I made some changes and instead of using joints I used contact Bonded cause in my situation my car jack is under the car and it's lifted on certain height. During my analysis the message showed up:
An unknown error occurred during solution. Â Check the Solver Output on the Solution Information object for possible causes.
Speakig of Joints You said that I don't need use all 16 joints. So which joints and where shoud I place them to make it work ?Â
Regards, Jacob
