Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Post processing result editing › Reply To: Post processing result editing
November 25, 2024 at 9:43 am
ok, thank you for your help, the code now works fine replacing the results i want to edit with the *VPUT command, now I have another problem. I need to update the equivalent stress plot to show the edited results to perform a fatigue analysis. Is there a command that can do such thing?
