Ansys Learning Forum Forums Discuss Simulation General Mechanical Help with a spring problem Reply To: Help with a spring problem
erik.kostson
Hi
First make sure the spring is body to ground and give a small stiffn. value to start with.
Then to do what you want put frictionless supports on all faces except the spring face.
Apply temp., and the spring gets compressed (say with 100 deg. C).
Use a spring reaction probe to look at the spring results
All the best
Erik
