Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Issues with getting result from interconnent analysis script › Reply To: Issues with getting result from interconnent analysis script
21307110070
Hello, thank you for your reply. The issue should not be related to the simulation device and code I am running. The problem is as follows: I defined the value of obj in the script of the interconnect analysis and added this variable in the output options, but the obj I obtained after the program ran is still empty. However, the same operation is performed in FDTD, where the script in FDTD analysis defines the value of T_avg. After the program runs, the value of T_avg can be obtained. Do I need any additional operations in interconnect to obtain the value of the variable in the script of the analysis?
