Ansys Learning Forum Forums Discuss Simulation Fluids Failed to generate surface mesh Reply To: Failed to generate surface mesh
Keyur Kanade
pmdb is required if you are using linux. You can directly import SpaceClaim file in Fluent Meshing. Please try this.
If you are using only single fluid volume to mesh, there is no need for share topology.
Please go through help manual for more details
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
