Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Explicit Dynamics analysis ends without error, but doesn´t reach 100% progress › Reply To: Explicit Dynamics analysis ends without error, but doesn´t reach 100% progress
bianchi.hernan97
Hey Chris, thank you for you answer,
I did not run the model with parallel processing.
I tried running the simulation with and without mass scaling, and with and without erosion control, but i still get the same problem.
Is this perhaps a limitation of the Ansys student version? I dont understand why if i use less elements in my mesh, the simulation reachs a higher progress percentage..
