Ansys Learning Forum Forums Discuss Simulation General Mechanical Access results from previously converged time step when the problem fails to con Reply To: Access results from previously converged time step when the problem fails to con
wrbulat
Hello Sergio,
No apologies necessary - this kind of code behavior mystifies me as well. I'll offer you two options:
1) You could very likely open the incomplete results file in MAPDL. From the start button, choose ANSYS yyyy release > Mechanical APDL Product Launcher. In the launcher dialogue, browse to the Solver Files Directory used by your project and click Run:
When the MAPDL GUI comes up you can read any of the existing results from the results file for post processing:
You can then create countour plots of results and reorient the viewing direction with the Pan-Zoom-Rotate dialogue box:
2) Read the results file into Mechanical (click on the "Toolbox" icon in the image below):
In the drop-down, choose "Read Results Files". You might want to locate/review the Help article below:
I hope this helps,
Bill
