Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Ansys 2023R1 Can’t check Result tracker during the simulation › Reply To: Ansys 2023R1 Can’t check Result tracker during the simulation
Dear Chris
Thank you for your help. I have check the sugesstion you had:Â
I set the display option to "average" but it still not working. The total deformation does not update either. The simulation are runing well, as the result information keeps updating. Our lab are switching 2022 R1 to 2023R1, this function worked very well in 2022 R1, but not in 23 R1 when we re-run this simulation without change anything. My workstation is i9 10920x with 64GB memorry. It would be fine to have 100k mesh. We also tested this funtion of 23R1 using another explicit model simulation in another more powerfull work station, same problem.Â
Yes right now we are using puase botton if we need to chekc the status during its running.Â
thank you again for your help!
Best,
