Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Ansys 2023R1 Can’t check Result tracker during the simulation › Reply To: Ansys 2023R1 Can’t check Result tracker during the simulation
Chris Quan
I reviewed the setup. I don't see any problems. I also created a test model to test the result trackers in 2023R1. It works.
You also have other results trackers under Solution Information. Will other results trackers such as Total Deformation work? Are you able to see the Total Deformation updated with time?
I noticed that Display Option is set to unaveraged. Will changing it back to the default "averaged" make the result tracker of stress work?
When the results tracker didn't update with time, did the model still run? If no, you need to check the model setup to find why it stopped running. If yes, you may move your model to another computer that has a larger size of memory to run it.
Finally, you can always interrupt the solve at any time during its running, check the results, and then restart it by selecting the last cycle number from Analysis Settings -> Step Controls -> Resume From Cycle.
