Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › ANSYS APDL – displacement constraints (D commands) in .CBDO file › Reply To: ANSYS APDL – displacement constraints (D commands) in .CBDO file
nils-erik.sanhen
thank you for your reply.
In the modelling procedure I followed the manual. And I was able to create a solid-solid submodel. But in the follow up step, to create a shell-solid submodel, I was not able to generate a .CBDO consist out of an NMODIF block and and D block (dexcriped on page 148 of the document). My model consist soly on NMODIF commands. So I try to figure out what the cause of the problem is and how I can fix it.
If you have further ideas or examples I could take a look on, I would be happy.
Best greetings,
Nils Sanhen
