Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Failed to generate surface mesh › Reply To: Failed to generate surface mesh
November 22, 2024 at 5:23 am
Have you done share topology? Is it successful? Can you post image after share topology?
Why pmdb file? Are you using linux for Fluent Meshing?
Do you want solid + fluid mesh?
I can see you have solids as well as enclosure in the image.
Please go through help manual for more details
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
