Ansys Learning Forum Forums Discuss Simulation General Mechanical About using apdl command in workbench Reply To: About using apdl command in workbench
ErKo
Hi
See *TREAD in the help manual.
Search here for TREAD, and or the internet – a quick search result:
https://www.eng-tips.com/threads/tread-command-problem.443210/
In the above, the file is located in the solver files dir. If in different folder, then add the whole folder path – say if file is in the D: drive use :::: *TREAD,mytable,’D:\mydisp’,csv,,to_skip
All the best
Erik
