Ansys Learning Forum › Forums › Discuss Simulation › Optics › ZEMAX CAD export problems with tilted surfaces › Reply To: ZEMAX CAD export problems with tilted surfaces
Hi Niki,
thank you for coming back to me. The parasolid library box is ticked.Â
I just tested unticking the box, and on exporting I get the error message "surface 12 failed to export". This is the standard surface just in front of the diffraction grating, making a tilted prism surface as the element is a grism.Â
On the plus side, the remaining surfaces are at the correct positions now. So I get the grating, but not the two tilted prisms around it. It is the 2nd element from the right now, the yellowish rectangle.Â
So chosing the parasolid library causes a mess up of tilted surfaces. Deselecting the library causes wedged surfaces not to export.Â
