Ansys Learning Forum Forums Discuss Simulation General Mechanical Composite Pressure Vessel Reply To: Composite Pressure Vessel
Mudassarbhisty
Can anyone give me suggestion/ solution for the following issue, i am facing while running a static analysis of a composite pressure vessel.
I am getting significantly higher stresses at the bottom region of the bottom ply only. The neighboring elements have stress magnitude comparatively lower than this strip of elements. I have attached the images for your understanding.
Thanks
