Ansys Learning Forum Forums Discuss Simulation Fluids Non-intersected faces at interface – periodic Reply To: Non-intersected faces at interface – periodic
michal.czerwinski
Thanks for your reply, unfortunettly it didn’t help either. I may found the true problem though.
Fluent can see that there are 2 periodic surfaces, when I measured geom in Spaceclaim we can see that the angle beetwen them is 60 deg. However when I tried to use auto offset mode, it showed warning. That suggest that the angle is diffrent. So now I wonder at what point could it happened? During meshing or during saving Spaceclaim file or somewhere else?
