Ansys Learning Forum Forums Discuss Simulation LS Dyna LS-RUN freezing Reply To: LS-RUN freezing
Reno Genest
I am not familliar with Alienware machines. I did a Google search and one difference is the Alienware command center. You can try to uninstall the Alienware command center and see if it works:
https://www.dell.com/support/kbdoc/en-us/000178439/how-to-remove-and-reinstall-the-alienware-command-center
https://www.dell.com/support/kbdoc/en-us/000179513/alienware-command-center-quick-guide
Reno.
