Ansys Learning Forum › Forums › Discuss Simulation › Fluids › CHT-Simulation (Steady-state) › Reply To: CHT-Simulation (Steady-state)
fyoussef
It seems that the wall thickness I previously defined as 1 mm is causing the imbalance in my system. How should I define the wall thickness to ensure a balance occurs on both sides of the heat source, specifically between the wall and the wall shadow? Thank you again for your assistance!
