Ansys Learning Forum › Forums › Discuss Simulation › Fluids › CHT-Simulation (Steady-state) › Reply To: CHT-Simulation (Steady-state)
November 20, 2024 at 4:27 pm
fyoussef
I’m not sure if I’m allowed to share such photos; I’ll need to check with my supervisor and get back to you. I’m sorry about that, but I hope you can understand what I mean.
When I report the heat fluxes, I calculate approximately 65 W from the heat sources, which I’ve already defined. At the same time, I observe a heat loss of about -15 W due to convection with the air. Based on this, the remaining difference of approximately 50 W should stay within the system and contribute to an increase in internal energy (likely as heat)—is my understanding correct?
