Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Holed surface in a channel › Reply To: Holed surface in a channel
chrivero
Thank you for your answer. I tried to do this approach because if I enable porous media the velocity inside the packed bed is all constant and I can't see any difference in radial direction as I expect
