Ansys Learning Forum Forums Discuss Simulation Fluids Non-intersected faces at interface – periodic Reply To: Non-intersected faces at interface – periodic
That should be OK. I assume the axis is set correctly? Also try -60 degrees as the order can matter in some cases.Â
