Ansys Learning Forum Forums Discuss Simulation General Mechanical At least one body has been found to have only 1 element in at least 2 directions Reply To: At least one body has been found to have only 1 element in at least 2 directions
deepak.deepak
Set the element size of the arms to 1.2mm, and Rest all to default.
For the contacts, select all contacts and right click > select "Renaming Results Based on Definition"
