Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › At least one body has been found to have only 1 element in at least 2 directions › Reply To: At least one body has been found to have only 1 element in at least 2 directions
kubatycjan
The arm thickness is 3mm . Which element size should I change to default ? Arms or the rest of the parts ?
It is showed in contacts bonded - no selection to no selection, even though I chose their contact and target bodies.
