Ansys Learning Forum › Forums › Discuss Simulation › Fluids › The streamline display issue › Reply To: The streamline display issue
November 20, 2024 at 11:58 am
We've had a few Forum issues, hence the delays.Â
The pathlines should show the flow speed, so unless the velocity is massively higher in the rotating part I'd not expect much of a difference. Pathlines also follow the flow, so what might cause them to behave as they are?Â
