Ansys Learning Forum Forums Discuss Simulation Fluids Pressure Drop analysis in Packed bed Reply To: Pressure Drop analysis in Packed bed
If you've moved the stl of the bed to Fluent why do you then need to use Rocky again? Or do you need to look at some moving particles above the bed?
Tutorials are in the Help, check the link I shared.
