Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Coupled field transient of brakedrum › Reply To: Coupled field transient of brakedrum
engr.rohan7
Hello Peter,
As per your suggestions, I applied the loadsteps with time integration turned off for first step.
After running the simulation, following are the results,
Total deformation-
The disc appears to be expanding for total deformation and joint probe (relative rotation).
Equivalent stress as shown below-
Joint probe as shown below-
This result is obtained for modified density after multiplying by a factor of 1000.
I've also tried a coupled field transient for this disc brake. I have kept time integration off for the first load step.
I have got a list of messages after the run as follows-
I am getting an error as follows-
The error is as follows as per solution output-
*** ERROR ***                           CP =    2216.203   TIME= 00:00:33
 Solution not converged at time 1.E-04 (load step 1 substep 1).
  Run terminated.
 Before the above error, a warning is seen as follows-
Contact element 20199 (real ID 6) status changes abruptly from contact
 (with target element 21278) -> no-contact.
The force convergence plot does not show the substeps converged,
Two physics region have been defined as follows-
Structural-
Structural- Thermal -
The frictional contact details are as follows-
I have also applied command snippets as follows-
Frictional contact-
Transient analysis-
Any suggestions for resolving these issues?
Another point, I would like to know how to get a temperature distribution in transient structural due to frictional braking?
As you mentioned, after increasing the density I could observe the rotational velocity increasing in the first load step after turning off time integration. So thank you for that suggestion.
Looking forward to your reply,
Rohan.
