Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Errors Running Ring Modulator Example on Cluster › Reply To: Errors Running Ring Modulator Example on Cluster
adevata
Hi Khash,
Thanks for your reply. I remember seeing your reply about running it locally at first, but I wasn't able to test it before I noticed that the reply was gone. I did edit my post today stating that I was able to run the simulation locally on Lumerical 2024 R1.3, and had no issues at all. However, as I point out in my edit, this is not a sustianable solution; I need to run this over the cluster.
Just to confirm, your recommendation is to do option a) I've listed above right? This ignores the parameter extraction completely. I just ran it again over the cluster right now (using option a)) and I got the same ldev error I included in my original post. The actual error message is quite a bit longer, with PATH, mpiexec/mpich2, nemesis, and munmap_chunk mentioned a couple times. If you'd like I can share the full error message, although most of it looks like gibberish to me (random numbers and letters strung together)?
I'm not sure if you are interfacing with my university on this issue, but if you would be willing to schedule a call sometime in the coming week I'd be more than happy to do that? For now, if you could let me know what next steps I should take to either run the simulation properly or to test/debug the issues we're having, please let me know.
Thank you for your time and help, and I look forward to your reply!
Cheers,
AD
