Ansys Learning Forum Forums Discuss Simulation LS Dyna I would like to use LS-Prepost software, which version is available? Reply To: I would like to use LS-Prepost software, which version is available?
kangjs1420
Thank you for your answer.
Running LS-Prepost is not a problem.
However, problems arise when I try to run the model after designing it using LS-Prepost.
License-related issues occur when running 'Run LS-DYNA' inside LS-Prepost.
Should I import the model designed using LS-Prepost to Ansys workbench and run it?
I have no experience using LS-Prepost, so I am not sure about this.
