Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Errors Running Ring Modulator Example on Cluster › Reply To: Errors Running Ring Modulator Example on Cluster
November 19, 2024 at 11:32 pm
kghaffari
Hi AD,
Sorry I think there has been an issue with the forum and my reply is lost. Please let me know if you received my response earlier.
In short, I think the issues are related to the CHARGE simulation not running. I recommend avoiding running the sweep for now but just testing with clicking run. I tested the example on my side and did not see the issue you describe. Can you confirm if the issues occur even if run on a local machine (and not cluster)? Currently we are not able to reproduce the issue.
Best regards,
Khash
