Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › LS-RUN freezing › Reply To: LS-RUN freezing
Reno Genest
Are you running on Windows or Linux? Which version of LS-RUN are you using?
Does LS-RUN freeze on all models? Have you tried to run a very small and simple model?
LS-RUN is a very light application used to run LS-DYNA. Are you sure LS-RUN is freezing and not LS-DYNA?
What is written to the output window when you click on the run button?
Reno.
