Ansys Learning Forum Forums Discuss Simulation Electronics Maxwell circuit – PWM Reply To: Maxwell circuit – PWM
Tamami Yamanaka
Ensure that parameter settings for the VPWM source are set correctly. Also, verify that the Type parameter is set appropriately to TIME or POS, depending on whether your output signal is a function of time or position.
Maxwell Help > Using the Maxwell Circuit Editor > Components > PWM Voltage Source:
Ansys Maxwell 2024 R2 – PWM Voltage Source
