Ansys Learning Forum Forums Discuss Simulation Electronics Crashes in 2024 R2 Ansys Electronics Reply To: Crashes in 2024 R2 Ansys Electronics
H.Shirzad2
Hi Timos,
I hope someone had already sent you the logs I sent them in ANSYS as this place does not allow for uploads. To tell you what happened, I simply drew a cube, assigned NdfeB 30 as the material. Then I changed the magnetization direction using the material properties tab. I ran the simulation and ploted H using right click on the magnetic cube. Once the H field was showing on the screen, I decided to press Ctrl+Z to undo the field shown and it crashed. I tried any 3D field plot and after undoing the drawn field using Ctrl+Z, the software crashes.
