Ansys Learning Forum Forums Discuss Simulation Fluids Workstation Ansys Fluent Reply To: Workstation Ansys Fluent
Rahul
Hello
What physics is being solved in your case?
The turnaround time can be reduced using a more number of CPU cores.
You can try decreasing the number of mesh elements to improve the speed.
Are you using a symmetry boundary condition? If your geometry is symmetric, you should be modeling half the geometry to improve the solution speed.
