Ansys Learning Forum Forums Discuss Simulation Electronics Please tell me the Y wiring circuit diagram. Reply To: Please tell me the Y wiring circuit diagram.
jjh4804a
The current was also set to 0.
When analyzed, the graph is not consistent and the desired value is not obtained. Is there a way to do Y wiring without using a circuit diagram?
When u, v, and w are grouped and interpreted, the graph is constant, but the back electromotive voltage value does not appear.
