Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Optimal meshing for accurate geometry sampling › Reply To: Optimal meshing for accurate geometry sampling
November 18, 2024 at 7:21 pm
I now see that there is “based on a structure” option available in the mesh override regions. But even if I use the mesh override snapped to the structure, the height value I extract from the refractive index monitor differs from the target value. Why is that the case?
