Ansys Learning Forum Forums Discuss Simulation Fluids FLUENT | Mass flow-rate report at inlet surface different to the specified value Reply To: FLUENT | Mass flow-rate report at inlet surface different to the specified value
hmanatunga
The mass flux report is consistent with the mass flow rate surface integral monitor. Specified value at mass flow rate at the fuel-inlet is around 2E-4 kg/s but the mass flux report at the fuel-inlet is around 1E-4 kg/s.
