Ansys Learning Forum › Forums › Discuss Simulation › Fluids › The behavior of the external fluid does not coincide with the rotor with involut › Reply To: The behavior of the external fluid does not coincide with the rotor with involut
November 15, 2024 at 5:36 pm
This last image is the rotor without casing. At first glance, the fluid behavior seems more real. That's why I was wondering if it is normal for the wrappers to have that behavior. Or should they be the same as this last image?
I always match the mesh with share of the spaceclaim. Should it have some interface?
The first image is the convergence curve.
