Ansys Learning Forum › Forums › Discuss Simulation › Fluids › The behavior of the external fluid does not coincide with the rotor with involut › Reply To: The behavior of the external fluid does not coincide with the rotor with involut
November 15, 2024 at 4:27 pm
You may need to do some more post processing to see what's going on - flow is going about where we'd expect but that may be masked by the higher core velocity. Angular velocity is a good one to review along with axial. Â
How well converged is the model?
