Ansys Learning Forum › Forums › Discuss Simulation › Fluids › The behavior of the external fluid does not coincide with the rotor with involut › Reply To: The behavior of the external fluid does not coincide with the rotor with involut
Middle image in the first post. There's a very visible jump in the contour. However, can you plot the same image in Fluent? CFD Post doesn't always read the moving zone/refrence frame so your data may be correct but you're displaying the velocity in the wrong reference frame.
