Ansys Learning Forum Forums Discuss Simulation Fluids The behavior of the external fluid does not coincide with the rotor with involut Reply To: The behavior of the external fluid does not coincide with the rotor with involut
josue
The black line is the projection of the output. the medium is just air. I use fluent.
I have tried another case without a wrapper, and the results are similar to visually normal behavior. but I have seen that the majority use the wrapper, and the same behavior is not achieved.
with wrap
without wrapper
