Ansys Learning Forum › Forums › Discuss Simulation › Fluids › The behavior of the external fluid does not coincide with the rotor with involut › Reply To: The behavior of the external fluid does not coincide with the rotor with involut
Can you check what the surface type is that bounds the rotor? There's a cylinder just a little bigger than the spinning part - look at the black line just outside the red parts of the contour.
Are you using Fluent or CFX?
