Ansys Learning Forum › Forums › Discuss Simulation › Electronics › current path for two different materials › Reply To: current path for two different materials
Timos
Hello, to impose a contact between the two materials and have Maxwell understand it as a single path of current, you may need to create a terminal (sheet object) that matches the cross-section of the conductor at the desired location for the contact. This terminal can then be used to apply the excitation (current/voltage) across the contact surface.
