Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How do I create this type of Mesh › Reply To: How do I create this type of Mesh
ae22b001
Hi so i tried to refine an existing mesh near the wall to reduce its ascept ratio. I wanted to split the cells into 2 to reduce its aspect ratio. To do that i set the minimum edge length to a value that is greater than the height of the cell. I expected it to only be refined in the other direction. However, it still splits the cell into 4, retaining its Aspect ratio. I split the zone into 2, to see a comparison of before vs after.
How do I get it to split into 2 cells and not 4? Is that possible?
