Ansys Learning Forum Forums Discuss Simulation Fluids FLUENT | Mass flow-rate report at inlet surface different to the specified value Reply To: FLUENT | Mass flow-rate report at inlet surface different to the specified value
Please can you check the Mass Flux Report in Fluent. Not the surface integral if that's what you were using.Â
