Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › why not all object moving only one part when run modal analysis › Reply To: why not all object moving only one part when run modal analysis
erik.kostson
Hi
Seems something is not connected there – see if the mesh is compatible or if the contacts are active etc. (Or somethng with strange material prop.).
Or if no contact at the far edge where max. disp. is seen in that mode, perhaps then it is just a natural mode of that inner structure, which seems connected on the left but free on the right hand side so it behaves a bit like a cantilever in 1st bending mode.
Make sure to think through the restrains and all connections etc.
All the best
Erik
