Ansys Learning Forum Forums Discuss Simulation Electronics Parameter sweep weird error Reply To: Parameter sweep weird error
Tamami Yamanaka
The error suggests that there is a mismatch between the parametric sweep setup and the actual design parameters or analysis setup. This can occur if there have been changes to the setup that were not reflected in the parametric sweep options.
Please review your sweep setup to ensure that the calculation ranges in the parametric sweep match the design options and that all entries in the Calculation Tab exist in the design, or clean up solutions and re-create the parametric sweep setup.
Tamami
