Ansys Learning Forum Forums Discuss Simulation Photonics ansys Charge simulation Reply To: ansys Charge simulation
Guilin Sun
Unfortunately by the forum policy we are allowed to give you general suggestions in resolving an issue. If you are eligible to have email support please send us email with your file attached.
Otherwise please refer to the troubleshooting article. Usually it is not a turnkey solution so you will need trial and errors to adjust the parameters. There are some physical mechanisms that may affect the simulation. However it might not be easy to find which one. It might need more physics insights to the device.Â
