Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Simulate Vacuum Flow react with Rubber Material › Reply To: Simulate Vacuum Flow react with Rubber Material
November 12, 2024 at 3:25 pm
Strictly we can't model vacuum in the CFD tools as the continuity assumption isn't valid. Technically there'a also nothing to flow? If you're looking at how a vacuum effects a hose shape I'd go with Mechanical and assign a pressure (force?) to the inner and outer walls. The Mechanical channel wil be able to give more comprehensive advice.Â
