Ansys Learning Forum Forums Discuss Simulation Fluids Adjusting Pressure Drop in Condensation Model (Lee and Mixture Model) Reply To: Adjusting Pressure Drop in Condensation Model (Lee and Mixture Model)
How much liquid have you got on the walls? Are you accounting for volume change in the gas if cooling is significant? I'd be very wary of artificially increasing the pressure loss without knowing why: is the flow then a result of your modelling or directly down to set values?
