Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Tutorial or Help for 2 way FSI › Reply To: Tutorial or Help for 2 way FSI
ashishkumar.gupta
I understand your point of view.
In Mech, giving Rotational Velocity to IR, OR = fix and applying cyclic symmetry and using the beta function ...so software knows i have the complete BB model.
In Fluent, similarly cyclic symmetry can be used. In Boundary condition, IR wall = RPM of IR in Mech & OR = stationary...ball I am not sure what to do...
But But it is a RADIALLY LOADED DEEP GROOVE BB, so NOT all balls encounter the same load and Hence, cyclic symmetry CANNOT be used.
I have tried by giving Displacement normal to the side faces (on both side) = 0 but that did not work out.
See the load distribution curve below.
Am I missing something here? Or could you suugest something for my case to model periodic movement...
